Is There a Native Database Connectivity Solution for Linux RT Devices?
Updated Dec 20, 2023
  • Raima Database API for LabVIEW
  • LabVIEW Real-Time Module
  • NI Linux Real-Time
I'm working with an NI device that runs on Linux Real-Time (RT). I need to communicate with a database through this RT operating system. Is there a native solution on this for Linux, similar to the Database Connectivity Toolkit for Windows?
There is not currently a native National Instruments solution for database connectivity directly from Linux devices. There are, however, third party add-ons for LabVIEW that implement database connectivity on Linux, including the SQLite Library for LabVIEW by Dr. James Powell and the Raima Database API for LabVIEW.
If you have a Windows machine available, you can also use this as an intermediary between your database and your RT device. To do this, you would create a program which receives data (via network shared variables or other methods) from the RT device and then uses the Database Connectivity Toolkit to write this data into your database.
