我已成功使用LabVIEW数据记录和监督控制(DSC)模块开发了一个实时应用程序,并且该程序在开发系统中成功运行。但是,当我尝试将应用程序部署到我的实时设备时,收到类似于以下内容的错误:
LabVIEW: Failed to load shared library NVIORef.dll: EVT_EnableValueChangeNotifications:C on RT target device
或
LabVIEW: (Hex 0x436) Failed to load shared library NVIORef.dll: TR_SetProp:C. Esnure that the library is present on the RT target. Use either MAX to install NI software or FTP to transfer customer libraries to the RT target
或
LabVIEW: Failed to load shared library dscProc.dll:ni_lvdsc_process_GetProcessListEnd:C. Ensure that the library is present on the RT Target
为何发生此情况,如何解决该问题?
