Unexpected XNode Error Occurred
Updated Jun 25, 2018
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
I opened up an FPGA VI, and receive the following error when I try to run it: Unexpected XNode Error Occurred
  • To correct this error, re-add the node to the block diagram, and re-wire everything into the new node.
  • If the error persists, repair the installation of LabVIEW RT and LabVIEW FPGA.
This error is often caused by corruptions.  Re-adding the function to the block diagram creates a new instance, effectively "resetting" the function.
