If you need to activate the Third-Party Software offline, you might try to use our Third-party activation code generation page. During the process, please make sure that the "User Code 1" and "User Code 2" were correctly copied. This code is usually 9 digits and it should be the same as the User Codes on the PC where LabVIEW is installed. You can verify your User Codes by opening LabVIEW >>Go to Help >> Click on Activate Add-ons >> Choose the software you would like to activate >> Select Use a Web browser on this or another computer to acquire an activation code.
Note: Third-Party Add-Ons for LabVIEW are offered by independent third-party providers who are solely responsible for these products. NI has no responsibility whatsoever for the performance, product descriptions, specifications, referenced content, or any and all claims or representations of these third-party providers. NI makes no warranty whatsoever, neither express nor implied, with respect to the goods, the referenced contents, or any and all claims or representations of the third-party providers.
