Use an Amulet Display With a CompactRIO
Updated Mar 28, 2018
  • CompactRIO Controller
  • Amulet Interface and Power Board
I want to use an Amulet Display with my CompactRIO controller. Which steps should I follow?
To connect to the Amulet Display, you can use your computer and the display's USB port, or through the embedded target’s RS-232 port.
Follow the Getting Started with Amulet Displays guide to use the Amulet Display API, and GEMstudio™ to program your Amulet Display.
With the Amulet Display, you are able to create custom applications and deploy them using the Amulet Deployment Utility. Applications are created using Amulet's software called GEMstudio. Once completed, the applications are compiled and *.pdb files are generated. Typically you deploy your *.pdb file directly from GEMstudio, but there are situations when you would want to deploy from a different host than the Amulet development computer. Read more about them, here: Three Ways to Deploy the *.PDB file to Your Amulet Display
