Writing to a TestStand Database Using Default Schema from LabVIEW
Updated Jun 14, 2018
  • LabVIEW Database Connectivity Toolkit
  • TestStand
I would like to write to a TestStand database that utilizes the default schema from LabVIEW.  How can I do this?
You can use the LabVIEW Database Connectivity Toolkit along with knowledge of the required database tables in order to write to a TestStand database.  The required tables for the default TestStand database schema can be found in the TestStand Help.  The Database Connectivity Toolkit includes many examples for getting started with logging to database tables including Database Logging.vi and Database Insert.vi.  More information on this toolkit can be found in the LabVIEW Database Connectivity Toolkit User Manual.
