How to Host Shared Variable Library on Real Time Target
Updated May 3, 2018
I want to host my shared variable library on my cRIO instead of on my PC for a critical application running on the field. How can I do that?
1. First click on the chassis --> new --> FPGA Target.
2. Then click on the FPGA Target --> new --> library. You should also be able to see all the modules that is inside the chassis within the FPGA target
