NI-MAX Missing "mfc140u.dll" and Won't Open
Updated Jun 17, 2026
When I try to open Measurement & Automation Explorer (MAX), it won't open, and I get an error saying
The program can't start because the mfc140u.dll is missing from your computer. Try reinstalling the program to fix this problem.
How can I fix this?
This error arises when their the mfc140u.dll isn't properly installed by NI-MAX or has become corrupted.  Since NI-MAX uses this C++ .dll in it's code base, your computer will need to have this file reinstalled to use NI-MAX.
Try the following steps to fix this issue:
Additionally, if you are running NI MAX on a 64-bit Windows machine, make sure you install both the x64 and the x86 DLL files.
