Can I use the USB-8452 as a Bus Monitor?
Updated May 3, 2018
  • USB-8452
  • NI-845x
I have an I2C system set up with external devices and would like to keep track and monitor the frames on the bus. Is it possible to use the USB-8452 as a sniffer to monitor bus traffic?
No, since the USB-8452 is an active master device it cannot passively monitor the Bus. You would need to write directly to your USB-8452 in order for it to read from the bus.
Likely an I2C Sniffer or Bus Monitors would work for this application.
