You can use the Sample Compression Express VI to compress, or reduce, an input signal. A reduction factor is the number of points in the input signal that you want to reduce into one point. For example, for a reduction factor of 5, the Express VI condenses every five points to one point based on the reduction method you select: Minimum, Maximum, Last, Mean, or Median.
Given the following input signal, the table below shows the effect each of the reduction methods has on the signal.
Signal: [5, 7, 3, 2, 1, 12, 4, 5, 18, 3, 17]
Reduction Factor: 5
The number of elements in the input signal is not a multiple of the reduction factor. In this case, the Express VI uses zero padding to add zeros to the end of the signal and create a complete reduction set.
Reduction Sets: [5, 7, 3, 2, 1], [12, 4, 5, 18, 3], [17, 0, 0, 0, 0]
| Reduction Method | Output |
| Minimum | [1], [3], [17] |
| Maximum | [7], [18], [17] |
| Last | [1], [3], [17] |
| Mean | [3.6], [8.4], [17] |
| Median | [3], [5], [17] |
Attached is an example of how to implement the Sample Compression Express VI
