Using cRIO 9074 Controller with NI-XNET
Updated Dec 19, 2019
  • cRIO-9074
  • LabVIEW FPGA Module
  • NI-XNET
  • NI CompactRIO
Can I use a cRIO-9074 CompactRIO Controller (Legacy) with NI-XNET?
The cRIO-9074 is a legacy device and not compatible with XNET. You can use the cRIO-9074 with NI-CompactRIO and NI-Industrial Communications for EtherCAT software.
If you need to use NI-XNET functionality to work with your devices, a workaround is to use NI-XNET on your host computer. You can then transfer the data to your RT via the different communication options
  • For example you can convert a signal to a raw frame using the XNET Convert.vi on your host computer. You can then send that frame data array to your target.
