MAX is not opening for my DAQmx Device
Updated Mar 27, 2018
  • CompactDAQ Chassis
I can't open up MAX, what steps should I take?
If MAX is not opening or opening and crashing immediately, there could be a few things at fault:
  1. A new software installation caused MAX to crash. Look at the last installation and see if removing it resolves the matter.
  2. There was an incorrect installation causing a complete failure in MAX. Reinstall using this resource to see if deleting and installing everything helps.
  3. Reach out to NI Support at ni.com/support if the above steps don't work
