Acquiring both raw voltage and scaled values using NI DAQmx
Updated Mar 20, 2018
How can I acquire both raw voltage and scaled values using NI DAQmx?
Currently it´s not possible to acquire in the same task raw voltage and scaled values. You could alternatively aquire the raw voltage and later use an expression node to scale your values with a custom scale.
You can start acquiring easily with LabVIEW shipped example Voltage - Continuos Input VI
