Peak Hold Averaging in LabVIEW
Updated May 13, 2025
  • LabVIEW Signal Processing Toolkit
How can I average my frequency data to hold the peak values at each frequency step?
The FFT Power Spectrum and PSD VI includes Peak Hold averaging as one of it's selectable averaging modes. Wire your data into the time signal input and select Peak Hold as the averaging mode in the averaging parameters cluster.
The FFT Power Spectrum and PDS VI is included in the Waveform Measurements palette, which is included with LabVIEW Full or higher.
