Secondary Ethernet Port Settings Revert to 0.0.0.0 on Reboot
Updated Mar 15, 2018
  • cRIO-9082
I'm setting up the second network port on my cRIO in NI MAX (Measurement and Automation Explorer), and when I change the static IP address and subnet mask, click Save and reboot the RIO, both fields reset to 0.0.0.0.
This behavior occurs when both the primary and secondary network ports are set to the same subnet. Try setting them to different subnets, and when you save and reboot, your desired IP and subnet mask settings will be maintained.
