Column to Column Connection in Switch Executive 2015
Updated Apr 18, 2018
  • Switch Executive
I have a switch module and I would like to make a column to column connection. When Reserved for Routing is enabled for the row, no columns can be selected and the following message is shown: This route cannot be created or modified because an endpoint is reserved for routing
You can set up the column to column connections in the Routes/Groups tab in Switch Executive. If you configure a route such as seen below, it should allow the routing, and will ask if you want to reserve the route.
By doing this, you should see the following route when you look back at the Schematic Configuration tab.
