NI 9230 Module Is Reading Incorrect Values
Updated Apr 17, 2018
  • NI-9230
  • LabVIEW FPGA Module
I am using the NI 9230 module with the NI CompactRIO chassis. The CompactRIO chassis is added to the LabVIEW project in the FPGA programming mode. I have created a VI to acquire data from the NI 9230 AIx channel and the module is configured to work with the IEPE sensor. However, When I compile and run the VI my AIx channel(s) reads 0V or incorrect reading. What could be the issue?
It is because the NI 9230 module is not configured to work in the acquisition mode. You should use the Start and Stop channels of the NI 9230 to put the module in and out of acquisition mode.
  • Start channel node controls when the NI 9230 starts acquiring data. If TRUE is written to the Start channel, the NI 9230 starts acquiring data.
  • Stop channel node controls when the NI 9230 stops acquiring data. If TRUE is written to the Stop channel, the NI 9230 stops acquiring data.
Refer to the NI 9230 Getting Started VI in the labview\examples\CompactRIO\Module Specific\NI 9230\NI 9230 Getting Started\NI 9230 Getting Started.lvproj for an example of using the Start and Stop channels.
The information in solution applies to the following modules when used in LabVIEW FPGA programming interface mode:
  •     NI 9218
  •     NI 9225
  •     NI 9227
  •     NI 9229
  •     NI 9232
  •     NI 9233
  •     NI 9234
  •     NI 9235
  •     NI 9236
  •     NI 9237
  •     NI 9238
  •     NI 9239
  •     NI 9242
  •     NI 9244
  •     NI 9246
  •     NI 9247
  •     NI 9250
  •     NI 9251
  •     NI 9770
  •     NI 9775
