Dock Palette in LabVIEW NXG
Updated Mar 15, 2018
  • LabVIEW NXG
I am using several functions from the same subfolder in the LabVIEW NXG Palette. I don't want to have to navigate to the folder every time I want to access a function from that folder. Is there a way to pin or dock the palette on the folder that I am looking at?
You can dock a folder of the LabVIEW NXG palette by:
  1. Navigate to the desired folder in the palette that is located next to the Navigation Pane
  2. Click the Dock Buttons symbol in the upper-right-hand corner of the palette folder as shown below.
The folder should now stay open in the palette. You can undock the folder by clicking the Undock Buttons symbol above the docked folder.
As of LabVIEW NXG 2.0, it is not possible to pin or dock the palette that you open by right-clicking on a blank part of the Panel or Diagram.
