SCXI chassis can be connected to either PXI chassis or PC. Below contains the required hardware and setup guide:
SCXI-1349 Shielded Cable Adapter
- This adapter goes on the back of an SCXI module. Determine the specific SCXI module that should be chosen for this by reading the SCXI Quick Start Guide.
- 62xx or 63xx DAQ card (68-pin with analog input channels) for computer or PXI/e chassis
- 68-pin cable to connect the SCXI-1349 to the DAQ card
The cable will be dictated by the DAQ card chosen. See the accessories from the product page to determine the cable type that will be used with your card. For example, it can be seen from the product page for the
PCIe-6351 that the SHC68-68-EPM cable would be purchased.
Setup in NI-MAX
Open NI-MAX and ensure you can see the DAQ card you have connected to the computer. Self-test to ensure functionality. Then, follow the steps below:
1. Right click on
Devices and Interfaces and click
Create New 2. Expand the
NI-DAQmx SCXI Chassis section and choose your chassis model and click
Finish3. Ensure the modules are setup properly in the
Modules tab to match the physical configuration of the chassis
4. Click the
Chassis tab
5. Ensure you have the
Chassis Communicator set to your DAQ device
6. Ensure the
Communicating SCXI Module Slot is set to the slot the SCXI-1349 adapter is connected to
After this, your DAQ card should be configured under devices and interfaces with the hierarchy of your chassis and the modules inside it.
The DAQ card used can also be any 68-pin E Series DAQ device, excluding 61XXE devices. For example, 60xxE series could also work in the setup. However, these devices are older and not recommended for new purchase.
Sampling Rate Limitations
The DAQ card chosen can limit the maximum sampling rate achievable from the SCXI channels. Maximum sampling rate will be 333 kS/s or the limit of the DAQ card, whichever is slower. The sampling rate from the SCXI channels will be further limited due to
multiplexing.
Due to multiplexing, the sampling rate per channel in the SCXI chassis will be further limited. This can be calculated by dividing the sampling rate by the number of channels.
For example, when using PCIe-6343, the maximum sampling rate is 500 kS/s. With this setup, maximum rate will be 333 kS/s or maximum sampling rate of the DAQ card. In this case, the DAQ card is faster, so the maximum sampling rate for the SCXI chassis will be 333 kS/s. This is then divided by the total number of channels. Using 3 modules, each with 32 input channels, that would yield 96 channels total. 333,000/96 = 3470 S/s = 3470 Hz is the maximum achievable sampling rate for any individual channel in the SCXI chassis, given this setup.
Daisychaining SCXI Chassis
With the hardware setup described in this article, it is possible to connect multiple SCXI chassis, sometimes also called daisychaining. Additional hardware will be required to daisychain, read more at
Configuring a Multichassis SCXI System.
Alternative for SCXI Chassis to PC
An alternative exists for connection to a PC from an SCXI chassis. The SCXI-1600 is a module that allows USB connection to a PC. This method does not support daisychaining.
The SCXI-1600 is not supported in Windows 64-bit. For USB support of SCXI on a Windows 64-bit operating system, use a USB mass termination DAQ device with 3 ports of DIO. Potential devices include the USB-6259 Mass Term, USB-6251 Mass Term, USB-6361 Mass Term and USB-6363 Mass Term.
