What Is The Ratiometric Input on the PXIe-4439?
Updated Jun 14, 2018
  • PXIe-4339
I see the specifications sheet lists ratiometric mode input ranges, what is this?
The ratiometric mode will change the input range on the PXIe-4339 depending on the excitation voltage. As shown below, it can have different ranges depending on if it has greater than 2.75 V or less than 2.5 V.
So if you have 10 V of excitation and have the range set to +/-10mV/V you will have a voltage range of 10 times +/-10mV or +/-100mV.
