Resolution Messing with LabVIEW Pop-up Menus
Updated May 3, 2018
When setting the external monitor scaling to 125%, opening LabVIEW on the primary monitor, pulling up any window, dragging that window to the external monitor, and clicking on anything that makes a pop up makes the popup menu/window appears to rthe right, it is always offset to the right.
If I change the scaling to 150% or greater, the menu doesn't even appear on the screen because it's offset so far to the right.
e
Unfortunately, this sometimes happens depending on the version of LabVIEW or due to the type of primary/external monitor. However there are some workarounds:
- Change the resolution of the primary monitor to match the external monitor
- Rather than scaling the main monitor, I adjusted to a resolution that preserved the aspect ratio but was equivalent to a 150% scale up
