Is the VI Analyzer Toolkit Included With LabVIEW?
Updated Mar 11, 2021
  • LabVIEW VI Analyzer Toolkit
I finished installing LabVIEW but I found it missing some features related to the VI Analyzer Toolkit, for example, the VI Analyzer VIs. Is this toolkit included with LabVIEW and is there any way of installing it if the features are not available after finishing the LabVIEW installation?
The VI Analyzer Toolkit is included with LabVIEW Professional Development System, if you installed LabVIEW and you are not able to find the VI Analyzer Toolkit, there are three main troubleshooting steps that you can try to activate/install the toolkit:
1. Activate
It may happen that the VI Analyzer Toolkit is already installed but not activated, please follow these steps to license the toolkit:
  1. Open the NI License Manager >> Local Licenses and verify if the toolkit is listed under Add-ons.
  2. If you see the toolkit on the list, you can activate it by inputting your serial number. For more information on how to activate your software, look at this article.
2. Install and Activate
The toolkit might not be installed for the LabVIEW version that you are using. In this case, please use the independent installation file for the toolkit and verify that it matches the LabVIEW bitness:
  1. Go to the download link: LabVIEW VI Analyzer Toolkit Download.
  2. Choose the right version of the software (32-bit or 64-bit).
  3. Download the software.
  4. Run the installer.
  5. Follow instructions on step 1 if the toolkit does not get automatically activated.
3. Repair Software Installation
If the VI Analyzer Toolkit is already installed but still not available from LabVIEW please proceed with repairing the toolkit installation by following the instructions in this article: Repair Software In NI Package Manager (NIPM).
You can check if the LabVIEW VI Analyzer Toolkit is included in your software bundle by taking a look at the table in the following link: Compare NI Software Suites
