Location of Header Files for IVI Drivers in LabWindows/CVI
Updated May 3, 2018
  • LabWindows/CVI
  • IVI Compliance Package
I recently installed an IVI driver to use in LabWindows/CVI. I need to find the header file, but am not sure where they are located on disk.
Header files are found in the Include folder in your IVI directory. This folder is typically located at C:\Program Files*\IVI Foundation\IVI, but the exact location could change based on how you install your IVI drivers.
*32-bit drivers will be installed to the Program Files (x86) directory.
