View an SVG Image in LabVIEW
Updated May 3, 2018
I have an SVG image that I'd like to display on my LabVIEW front panel, or at least have accessible to the user. Is there any way I can do this?
LabVIEW does not natively support SVG images in PictureBox controls, but you can view SVG type images by using one of two methods.
1. Use the Open in Default Browser.vi
  • Wire the filepath to the image to the URL terminal.
    • This will only work in Internet Explorer browsers that are newer than version 7, but should work in Chrome and Firefox as well.
  • Run the VI. The SVG image should appear in a separate browser window.
2. Use an IWebBrowser2 ActiveX Invoke Node.
  • Create an IWebBrowser2 control on the front panel.
  • On the block diagram, create an ActiveX invoke node and wire the IWebBrowser2 control into the invoke node.
  • Wire the image's filepath to the URL terminal of the invoke node.
  • Run the VI.
