Initial troubleshooting steps for LabVIEW internal errors and crashes:
- Send the crash report to NI via the LabVIEW Crash Reporter dialog box. Add any relevant information that will aid NI in diagnosing the crash.
- Determine if you can reproduce the crash consistently. This will make diagnosing the source of the crash easier. If you can reproduce the crash, then try searching the KnowledgeBase and the NI Community for similar crashes. Include the hex code and what you are doing when the crash occurs.
- Install the latest LabVIEW patch.
- Check the LabVIEW Known Issues list for your LabVIEW version.
Further troubleshooting steps:
- Try to narrow down the source of the warning. Reduce down the code and the amount of hardware used to create the smallest reproducing case of the crash. If you can eliminate the parts that are not related to the crash, it is more likely to find the root cause of this specific crash. Please see the following troubleshooting steps to help in doing this:
- If the crash happens with an executable, check if the same behavior occurs when running the VI from the LabVIEW development environment. Doing this may point to an issue with the Run-Time Engine.
- Try using a Diagram Disable Structure to disable parts of your code. This can help narrow down where in your code the crash is happening.
- Try removing all hardware. If you still see the crash, then you can continue troubleshooting the software. If removing the hardware fixes the crash, then you can narrow the cause to the hardware. Try using a different kind of hardware to see if the crash is specific to the type of hardware.
- Check if you see the same behavior on a different computer. The crash could have something to do with the environment of the computer.
- Monitor memory to check for memory leaks.
- Use WinDbg to troubleshoot the crash. If the crash is reproducible, then attach this tool to the LabVIEW process and cause the crash to happen again. This tool can give you a more in depth look at the source of the crash.
- If you are using hardware, ensure you are closing every memory reference. Any misuse of the references could cause a memory leak.
- Make sure that all the error clusters are connected and being monitored. An error may have occurred earlier that you are unaware of. Error numbers are there to specify what went wrong and can be searched for in the Explain Error dialog box (Help»Explain Error...) to find an explanation about the error.
- If you are using .NET framework or DLLs, try removing them to see if the crash still happens. The DLL could be where the crash is happening.
- If the crash occurs consistently with just one VI, try copying the entire contents of its block diagram to a new VI. Sometimes this can remove corruptions that can cause crashes.
- Mass compile your VIs. If you upgraded LabVIEW from an earlier version, you may have some older VIs that were not updated.
- The crash could also be happening because of an "Insane Object" or "fsane.cpp" error in your code.
- Look at the LabVIEW Error Log, or the Real-Time Error Log if dealing with a Real-Time system.
- If crash is ocurring in an executable, ensure all necessary drivers are installed on the deployment machine.
- Implement your own logging to gain more information on where the crash may be occurring.
- Turn off the firewall and try to run your project. Some antivirus software, such as SentielOne, contain dlls that cause LabVIEW to crash.
- Ensure you are not exceeding the maximum size of the block diagram or front panel.
- Use LabVIEW Desktop Execution Trace Toolkit , to perform advanced debugging using dynamic code analysis.
Additional troubleshooting steps:
If the root cause of the crash can be determined, the next step is to find a workaround or reproduce the crash on the smallest possible scale. If it is a LabVIEW bug, then a Corrective Action Request (CAR) can be filed by
contacting National Instruments Technical Support. Attach an example VI that demonstrates the crash as well as any supplementing files obtained from the above steps. This will help our Technical Support Engineers replicate and best understand the problem.
It might be possible that the issue is related to a corruption of the software or even the operative system. If you've tried the troubleshooting steps mentioned above and you were not able to resolve this, you might need to consider reimaging the computer.
