Applying Custom Scale to One Channel During Channel Expansion using DAQmx
Updated Mar 15, 2018
I am using channel expansion for one analog input task, but I only want to apply my custom scale to one channel. Is this possible? How can I do this?
This is possible by connecting and then configuring each channel using DAQmx Create Channel.VI in the same task as shown in the picture below. However, if the scales between the channels are very different, the graph will not show a good visual of both signals.
