9208 Analog Input 20 mA - Connect Passive and Active Sensors
Updated Dec 2, 2022
  • NI-9208
I want to connect active and passive sensors on my 9208.
Is it possible ?
Yes, you can connect passive and active sensors on the same module.
To connect your signal :
  • Passive sensor :  between Vsup and AIx.
  • Active sensors : between AIx and COM  (Thus, you do not use the Vsup pin and you do not power your sensor via the 9208 module)
