How to Recover from the Bus off State in NI-Embedded Can for RIO
Updated Jul 25, 2018
  • sbRIO-9636
  • LabVIEW 2017 Professional
  • NI-Embedded CAN for sbRIO
  • NI-Embedded CAN for RIO
How can I recover the CAN bus if it transitions into the Buss Of state?
Recovering from the Bus Off state can be done by calling the following VIs in the following order:
1. Can Close Interface VI
2. Can Create Interface VI (with the right settings so you do not end up in the Bus Off State again)
3. Can Start VI
Make sure to properly clear and handle errors. You should not have to reboot or power cycle.
Note that the driver changed name from "NI-Embedded CAN for sbRIO" to "NI-Embedded CAN for RIO" in release 14.0.
