How Can I Disable Specific Test Sites During a Test?
Updated Mar 20, 2018
  • NI TestStand 2014 SP1 Semiconductor Module
With the default NI TestStand Batch Process Model - without using NI TestStand Semiconductor Module - you can disable a specific Test Socket via the UUT Information dialog box or the underlying callbacks.
However, when using the TestStand Semiconductor Module, the Operator Interface does not display a checkbox to disable a specific site. I am also unable to find a recommended approach in the documentation.
The recommended approach to disable specific sites depends on the software version you are using.
In NI TestStand Semiconductor Module 2016 (and earlier) you should
  • Create a simulated handler.
In NI TestStand Semiconductor Module 2016SP1 (and later) you can
  • Use the AvailableSiteNumbers Property from the NI TestStand Semiconductor Module Station Settings.
The AvailableSiteNumbers Property can only be set from the NI TestStand Semiconductor Module Station Settings callback.
