该内容不适用于您选择的语言
Software Requirements for FPGA Compile Cloud Service
Updated Aug 2, 2023
  • LabVIEW FPGA Module
  • FPGA Xilinx Compilation Tools
I am considering using the FPGA Compile Cloud Service or Compile Farm Toolkit for my FPGA compilations. Do any features require the Xilinx Compilation Tools to be installed on my local PC?
If you use the FPGA Compile Cloud Service or Compile Farm Toolkit, you won't need to install a local compilation server like Xilinx Compilation Tools on your PC. As explained in LabVIEW FPGA Module Compatibility with Windows 10, you will only need these tools if you choose to locally compile your LabVIEW FPGA Code.
Use the local compile server if your system is not connected to the network.
