Does LabVIEW NXG Support TEDS?
Updated Mar 15, 2018
  • LabVIEW NXG
Does LabVIEW NXG support TEDS sensors?
Yes, you can use the NI-DAQmx driver with LabVIEW NXG, and the NI-DAQmx driver supports TEDS sensors. For more information on how to use TEDS sensors with NI-DAQmx, see the related links.
NOTE: The TEDS Library is separate from NI-DAQmx, and is not supported with LabVIEW NXG. If you need to use the TEDS Library, consider using LabVIEW for your application.
