Move Files Using LabVIEW
Updated May 15, 2023
Is it possible to create a VI that moves files from one directory to another?
Yes, you can use the Move Function to move files from one directory to another. You'll want to specify the file name at the end of the source path input. For example, if you want to move the file "temp.txt" which is located on the desktop, your source path would be:
C:\Users\<your username>\Desktop\temp.txt
Inputs and outputs for the Move Function.
