I Get "Exception Access Violation" Error When Selecting Device's Channels Using DAQ Assistant.
Updated May 3, 2018
I received an error window with the next message Assistant 17.0 encountered a problem  -
Exception access violation when trying to select device's channels using DAQ Assistant.
    Follow the next steps to solve this error:
    1- Check which version of the NI-DAQmx driver you have installed. This article guides you through this.
    2- Check if the NI-DAQmx driver is compatible with:
    • Your operative system.
    • The version of LabVIEW you are using.
    • The devices you want to use using your application.
    The information required on step number 2 can be found in the corresponding readme of each NI-DAQmx version.
    Once you checked this, there are two recommended options you can do to fix the error:
