Output 40V On All Channels Of The NI 9269
Updated May 3, 2018
  • NI-9269
  • In the data sheet of the NI 9269, it says that it can output up to 40V stacked. I would like to output 40V on each channel of this card. How can I do this?
  • If I stack analog outputs to increase the voltage, do I reduce the total number of analog outputs available to me?
Stacking analog outputs on the NI 9269 reduces the total number of outputs available. Stacking two channels allows for three loads, stacking three channels allows for two loads, etc.
This is the case because the output current of the first channel flows across two channels. For more information regarding this question, feel free to read the getting started guide
