LabWindows™/CVI™ Compiler Optimization Levels
Updated May 11, 2018
  • LabWindows/CVI
The compiler in LabWindows/CVI 2013 and later supports optimization for space and three different optimization levels for speed that can be configured in the Build Options. What is the difference between the three optimization levels for speed?
LabWindows/CVI 2013 and later uses the Clang compiler C frontend and LLVM compiler infrastructure to optimize applications for either space or speed. LabWindows/CVI allows the user to configure which of the LLVM speed optimizations are used when compiling an applications with a set of three levels of optimization aggressiveness. Level 1 optimization is least aggressive and level 3 is most aggressive. Each of the three levels uses a set of transform passes (i.e. optimization options) to determine which optimizations are performed. The following lists contain the transform passes used for each optimization level:
Level 1
Level 1 also includes three undocumented transforms.
  • -early-cse
  • -correlated-propagation
  • -loop-idiom
Level 2 (includes level 1)
Level 3 (includes level 1 and level 2)
