LabWindows™/CVI Variable Works in Debug Mode but Not in Final Package .EXE
Updated Jul 12, 2018
  • LabWindows/CVI
On of my variables in my .exe does not work in my final package of my LabWindows/CVI application. The variable in the GUI appears to be a zero.  It works fine in debug mode.
Be sure you are using the correct optimization mode when creating your executable. First check if "No Optimizations" fixes the variable in your Build Options. Then look at the document LabWindows™/CVI™ Compiler Optimization Levels to choose which is the best optimization for your application.
