Which Installation File Should I Use When Installing LabVIEW Run-Time
Updated Mar 13, 2018
  • LabVIEW Run-Time Engine
I would like to install LabVIEW Run-Time however after downloading the installation file I found there were two different installation files .exe and .msi. Which installation file do I use to install the Software?
Both file formats can be used to install the software - they just do it differently.
  • A MSI file is an executable file that is used for the installation, maintenance, and removal of software on modern Microsoft Windows systems. MSI is short for Microsoft Installer.
  • An EXE file is a short for ‘executable’ and has an .exe extension. The main purpose of an executable file is to install or run files that are already installed on the computer.
