Default Condition Terminal Using DB Tools Update Data
Updated Mar 7, 2018
What happens if you leave the Condition Terminal unwired to use the default input, while using the "DB Tools Update Data Vi"?
The Condition specifies an SQL clause that this VI uses to filter the selection criteria. This VI appends this clause to the end of an update statement. For example, where (col1 > 10). If you do not specify a value for this input or if the input is an empty string, this VI updates all rows in table.
Please note when using Context Help (CTRL+H) in LabVIEW, the option for Detailed Help is available for more details with LabVIEW functions.
