Using The Transpose Property Node With The XY Graph
Updated May 3, 2018
The Transpose property node for the XY Graph does not work, why is this property node not working with the XY Graph?
The Transpose Array property node is similar to the Transpose Array item on the shortcut menu of a graph or chart. Currently the Transpose Array is not supported for the XY Graphs.
If you require data to be Transposed and displayed on the XY Graph, the alternative approach would be to use the Transpose 2d Array Function.
Please Note we are currently working on updating the Transpose Array Property node within the XY Graph option.
