sbRIO Voltage Levels for RS-232/RS-485/RS-422 Ports
Updated Aug 21, 2024
  • sbRIO-9626
  • sbRIO-9627
Which are the logic levels that the on board sbRIO RS-232/RS-485/RS-422 ports?
Output Logic States
RS-232
RS-485/RS-422
High Logic
+5.5 Volts
TX+ set to +5 Volts
TX- set to 0 Volts
Low Logic
-5.5 Volts
TX+ set to 0 Volts
TX- set to +5 Volts
The RS-232 and RS-485 ports on the sbRIO are meant to be connected to other RS-232-compliant and RS-485-compliant devices. There is no need for external level translations or transceivers as they are already built in.
Image: sbRIO-9626 Console out RS-232 signal when booting up in safe mode
