Error -1074118529 Occurred at NIScope Fetch WDT
Updated Mar 5, 2018
  • PCI-5922
  • PXI-5922
  • NI-SCOPE
I was able to setup my test with PXI 5922 and it worked fine. But suddenly I kept receiving the following error message almost every two hours. I have to restart the systems in order to restore the communication with the scope.
I'm having the following error:
Error -1074118529 occurred at niScope Fetch WDT.VI
Hardware clocking error occurred. If you are using an external sample clock, make sure it is  connected and within the jitter and voltage level specifications at all times
Status code -238810.
Follow the next steps to resolve the issue:
  1. Check the cable connecting the host and the chassis. It causes on-off communication issues and subsequently results in the error shown.
  2. Replace the cable.
  3. If the error still appears, contact National Instrument Support.
