Can't Find Database Toolkit VI's On the Block Diagram
Updated May 3, 2018
  • LabVIEW Database Connectivity Toolkit
I can't find the Database tools even though I have the Connectivity Toolkit properly installed with LabVIEW. I am using the 64-bit version of LabVIEW 2017.
  1. Check to make sure that the Professional Development and the Database Connectivity Toolkit are properly installed and activated on NI License Manager.
  2. Check to see if multiple versions of LabVIEW are installed in the computer as the Toolkits may be installed in the wrong version.
  3. Make sure that the 32-bit version of LabVIEW is running since the Database Connectivity Toolkit is not supported on the 64-bit version of LabVIEW.
