DIAdem Crash When Launched
Updated May 3, 2018
  • DIAdem
When launching DIAdem it will crash after the splash screen and close with zero error messages.
Uninstall and re-install DIAdem. The installed launch application has become corrupt and not working as intended.
Other way round the issue if immediate uninstall is not an option due to account access or time constraints:
First ensure that there are no background process running by using Task Manager then launch the application from the root folder as found in:
C:\Program Files (x86)\National Instruments\DIAdem
This can be launched by navigating to this folder using File Explorer or Command Line.
The following can be used in command line to launch applications:
start D:\Any_Folder\any_program.exe
or when the file path contains spaces:
start "" "D:\Any_Folder\any_program.exe"
