NI USRP-2954R Not Visible in LabVIEW Communications System Design Suite 2.0
Updated Aug 29, 2018
  • USRP-2954
  • LabVIEW Base
  • LabVIEW Professional
  • LabVIEW Communications System Design Suite
I used to develop code for NI USRP-2954R in LabVIEW. Now I would like to start using LabVIEW Communications System Design Suite. After installing this software, device is not listed in hardware. How I can solve this issue?
Driver installation order is very important for every National Instruments device. You should install application software, such as: LabVIEW, LabVIEW Communications System Design Software, or LabVIEW Communications System Design Suite, before installing NI-USRP driver.
To add support for application software installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
