The error indicates that the directory containing the image is not found. To resolve the issue, reformat the target. Refer to
How Do I Format My Real-Time Target and Reinstall the Software? for steps on formatting the real-time target and reinstalling the software. Make sure to select the Reliance file system format as it is compatible with PXI targets.
The error indicates that the remote target/host cannot be contacted. Make sure the image deployed is the same controller model. If you receive an image from a specific controller, you can only deploy that image to the controllers of the same model number.
This error can indicate an issue with communication between the target and host. Ensure network connection, and firewalls are configured correctly.
