Using the 9212 in FPGA Mode
Updated Mar 21, 2018
  • CompactRIO Chassis
  • NI-9212
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
I want to set the TC type for my 9212 while using FPGA mode. I know there is an option in scan engine mode.
If using the 9212 with your FPGA you will need to look at the sample LabVIEW project. It's called "NI 9212 Getting Started" and you can find it using the LabVIEW Example finder located under Help>>Fine Examples. You will be able to set the TC type in the Host VI in the project.
