Which ESI File Should I Use With My Parker P-Series Drive?
Updated May 3, 2018
  • LabVIEW SoftMotion Module
I have a Parker P-Series drive and am using the SoftMotion Drive Interface Plug-In for Parker P Series drives. Which ESI (.xml) file should I use in my LabVIEW project?
As per our Getting Started with SoftMotion Drive Interface (SDI) article, the SDI Plug-in will contain a modified ESI (.xml) file which is what should be associated with the drive in your LabVIEW project, as opposed to the standard ESI file from Parker Hannifin.
