When I open a LabVIEW project that uses an FPGA target, my FPGA target is replaced with a yellow exclamation point:
When I click
Explain Warning, I get one of the two following errors:
- Software support for this FPGA target is not installed on the computer. You can view and copy some of the items in the project, but you cannot compile any VIs under this FPGA target until you install the target support. Refer to the specific hardware documentation for information about the appropriate drivers and for information about installing and configuring the FPGA target.
- The plug-in for the selected item is not installed on your system or the plug-in has an expired license. Please contact National Instruments.
How can I troubleshoot this issue?
