Error -363523 When Using PXIe-2727
Updated Mar 13, 2018
  • PXIe-2727
  • NI-272x Reference VIs
I'm using the PXIe-2727 driver in LabVIEW, and when I try to write a resistance value to a channel, then disconnect the channel in order to make the channel an open circuit, I receive this error.
What could be causing this error?
Make sure to connect the channel, write to the channel, then disconnect. Typical programming flow should look something like the image below.
