Select the Ratsnest for Specific Components in Ultiboard
Updated Apr 23, 2018
  • Ultiboard
I am using Ultiboard and, due to the complexity of the project, it is hard to identify where each unroute is going. I would like to be able to turn on only rats nest on a per-component basis.  Is this possible, or just on a net by net basis?
It is not possible to select the ratsnests for a specific device. However, if you have the ratsnest disabled in the Layers tab of the Design Toolbox, when you pick up a component, it will highlight all the wires associated with it.
You can show or hide individual ratsnests from the Show ratsnests column in the Nets tab of the Spreadsheet View, and also from the Net Edit dialog box.
